have a question here.. using the stock WG solenoid, if i adjust my wastegate rod so at WOT, its say, 16 psi, then if i put in the chip 100% dc, it should be 16 psi, right? trying to figure out a way to control boost during rpm, i currently have my turbo hooked up tuner style.. problem is, at wot it can handle boost, but at part throttle it doesnt like it, detonates.. if i turn my boost down 1.5 turns, then at wot is almost 15 psi.. will the stock wg solenoid setup work the way i want it to or what?
