Hello Forum,
I need your help. I have an 87' GN with 37,000 miles and mods listed in signature.
Recently, within the past 500 miles or 2 months, the car noses over when accelerating under full throttle from a stop. It will take off nicely until about 3-4,000 rpm, then nose over. I noticed on the scanmaster yesterday that when this happened, the Milivolts went to 0 and stayed there a few seconds after lifting from the throttle. The power seems to return going into second and third gear. Knock has been at zero.
In addition, I have adjusted the TT chip fuel settings with no luck. I thought it might be running too rich in first gear.
Since spring, I had to replace the MAF Sensor do to failure of the original. This is a "new refurbished" from Autozone. In addition, I also changed the O2 sensor with one from Autozone.
I would appreciate your thoughts on how I should proceed in diagnosing this issue. What other Scanmaster numbers should I look for, etc,?
Thanks!
Matt
Thanks!
Matt
