Tori
- Nov 4, 2013
I've read thru 2 pages using the search on body mounts, but still have a few questions.
I've never replaced body mounts before so don't have a clue what it entails.
From what i've read, sounds like its fairly common to loose the lower bushing. I think i've seen this under my car, so pretty sure i have at least one missing lower. I've also noticed the others are pretty squished and cracked.
I see some people only replace the lower. Why is this ? Does it do any good to only replace the lower ? Or can you not do the upper without taking the body off or something ?
I also read that a lot of the bolts break, or twist in the frame. If i have that happen, what is the out come of that ? Am i screwed until i pull the body off the frame or can it just be left alone ?
Also, i want to replace them with stock rubber ones. Not Poly. Suggestions for retailer ?
