I have 3 parts cars 2 were broke i sold the other to a member here. You can get them at the bone yard, you just need to open the glove box door all the way so it hangs then disconnect the cable rod to the arm so you can turn it a little more so the notches line up in the case so you can just pull it up and out. Should not cost much at a bone yard if they even charge you at all.
