FORGED 109 Long block
-.040 over 109 (decked .020) , Diamond pistons and rings, K1 forged rods, cleveite bearings, Eagle crank, JW flexplate, BHJ balancer (nuetral balance). RJC girdle, GN1 14 bolt heads (decked .008) with pedestal mount Scorpion 1:55 roller rockers. Ported stock lower intake, heads ported to match intake. ARP head and main studs. 215/220 roller cam, Comp roller lifters. Rollmaster billet timing set, upgraded front timing cover with oil passages drilled. 2200 street miles, no track passes-$4500. Engine was built by Red of Eastern Virginia Turbo Buicks in Nov of 2006.
-TCI TH400, (rated to 900HP) JW ultrabell, full manual reverse valvebody. $1100 -2000 street miles, no track passes. -PTC 9" 3600 stall $450
-3.5" Aluminum driveshaft for TH400, new u-joints, freshly balanced, and Spicer front yoke- $350
-TH400 poly trans mount for stock xmember- $75 new
-detent plate for factory shifter and TH400 $20 new
-Turbonetics T70 P Trim, polished comp housing, JH2000 black .85 exh housing, 2200 miles, no track passes $750 PENDING SALE
-83# inj set of 6 - $300
-Champion billet fuel rails with braided SS crossover for stock style FPR $200
-Razors Progressive alky kit- $450
-FAST XFI with Caspers Buick adapter box, ready to go, never installed $1800
-ATR 3" external DP, JH coated but peeling near WG $300
-Turbonetics Evolution WG, multiple springs- $200
-ATR SS headers, JH coated but peeling in some places $600
-Complete rebuilt front end kit, all urethane bushings, new ball joints, tie rods etc PST components--$300, installed on control arms already
-PTE front mount I/C tube and fin, $550
-4" Big Mouth CAI filter to turbo inlet, with MAF pipe set up for MAFLESS- $150
-RJC billet pullies- complete set $425
-HR parts poly drivers side engine mount $50 PENDING SALE
-ATR driveshaft safety loop $50
-4 springs front/rear $200 2200 miles
-Weld Pro Stars 15x7 front, 15x8 rears, 275/60/15 MT Drag radials and 2 new front tires, forget the brand 2200 miles $750
Accell coil and GM CCCi- $200 2200 miles
-have complete -6 AN trans cooler lines from radiator to aux trans cooler and trans $100
-Complete -8 AN fuel feed line with y-block at tank for dual in tank pumps $200
-Dual intank Walbros 255 lph with hangar $200
-8.5" POSI GN rear, stock 3:42 carrier ring and pinion, TA perf girdle, Moser 28-spline axles, S10 wheel cylinders, 4 large brake shoes, aluminum drums $1200
-Metco lower rear trailing arms $225
-Metco adj upper rear control arms $225
-complete vacuum brake conversion $100
-HR PArts rear sway bar-$425
-Underhood braces $25
-front frame braces $25
-aluminum bumper supports front and rear $75 each
-Complete 87 Interior, T-Top car
-Fenders, clean, no rust $100 each
-RS tail light $50
-Caspers MAF/TPS/FAST harness $50
-Caspers 14 gauge injector harness powered from back of alternator, BRAND NEW $90
-steering wheel with good center cap and screws, no cracks- $150
-hood, 1 spot on corner might be putty, have a look, $50 has emblems
-t tops $50
