Big ol' honkin parts list, Hi-Perf
FastRegalWE2
Wish I had another Buick!
The car is disassembled now, the only thing not out is the engine and trans. Now that I have 2 jobs, another baby on the way, I am not going to have time for this car. I am NOT backing out this time, as now the car is taken apart. 95% of this list is off the car and ready to go out the door.
-Shell with frame, no suspension-$1500
-FORGED Long block
-.040 over 109 (decked .020) , Diamond pistons and rings, K1 rods, cleveite bearings, Eagle crank, JW flexplate, BHJ balancer (nuetral balance). RJC girdle, GN1 14 bolt heads (decked .008) with pedestal mount Scorpion 1:55 roller rockers. Ported stock lower intake, heads ported to match intake. ARP head and main studs. 215/220 roller cam, Comp roller lifters. Rollmaster billet timing set, upgraded front timing cover with oil passages drilled. 2200 street miles, no track passes-$4500. Engine was built by Red of Eastern Virginia Turbo Buicks in Nov of 2006.
-TCI TH400, (rated to 900HP) JW ultrabell, full manual reverse valvebody. $1100 -100 street miles, no track passes. -PTC 9" 3600 stall $450
-3.5" Aluminum driveshaft for TH400, new u-joints, freshly balanced, and Spicer front yoke- $350
-TH400 poly trans mount for stock xmember- $75 new
-detent plate for factory shifter and TH400 $20 new
-Turbonetics T70 P Trim, polished comp housing, JH2000 black .85 exh housing, 2200 miles, no track passes $750 PENDING SALE
-83# inj- $300
-Champion billet fuel rails with braided SS crossover for stock style FPR $200
-Accufab AFPR $75
-Precision 70mm upper plenum $150
-Precision 70mm TB $175
-Razors Progressive alky kit- $450
-FAST XFI with Caspers Buick adapter box, ready to go, never installed $1800
-ATR 3" external DP, JH coated but peeling near WG $300
-Turbonetics Evolution WG, multiple springs- $200
-ATR SS headers, JH coated but peeling in some places $600
-Complete rebuild front end kit, all urethane bushings, new ball joints, tie rods etc PST components--$300
-PTE front mount I/C tube and fin, $550
-4" Big Mouth CAI $150
-RJC billet pullies- complete set $425
-HR parts poly drivers side engine mount $50
-ATR test pipe w/dump $40
-ATR driveshaft safety loop $50
-4 Bilstein shocks- $325 2200 miles
-4 springs front/rear $200 2200 miles
-Weld Pro Stars 15x7 front, 15x8 rears, 275/60/15 MT Drag radials and 2 new front tires, forget the brand 2200 miles $750
-Ramchargers dual fans with PnP harness $75
-Accell coil and GM CCCi- $200 2200 miles
-have complete -6 AN trans cooler lines from radiator to aux trans cooler and trans $100
-Complete -8 AN fuel feed line with y-block at tank for dual in tank pumps $200
-Dual intank Walbros 255 lph with hangar $200
-braided SS turbo oil feed and drain lines $75
-aluminum core support, cleaned painted black and uncut $250
-8.5" POSI GN rear, stock 3:42 carrier ring and pinion, TA perf girdle, Moser 28-spline axles, S10 wheel cylinders, 4 large brake shoes, aluminum drums $1200
-Metco lower rear trailing arms $225 with weld on relocation brackets $225
-Metco adj upper rear control arms $225
-complete vacuum brake conversion $100
-F Body alum radiator $50
-HR PArts rear sway bar-$425
-All frame braces, underhood, front frame , rear seat $125
-aluminum bumper supports front and rear $75 each
-Complete 87 Interior, T-Top car
-Fenders, clean, no rust $100 each
-3 piece spoiler $100
-tailights $50 each
-Caspers MAF/TPS/FAST harness $50
-Caspers 14 gauge injector harness powered from back of alternator, BRAND NEW $90
I will probably add more stuff later
All prices are less shipping, Pay Pal add 3% for their fees. I do need some time to get boxes together and get things packed up as they sell. I have 2 jobs so time is short and I also have to drop off the stuff in town at Fed Ex since I live rural they wont pick it up from my house. If a part is something needed ASAP, please let me know ahead of time.
Jeff
atr headers
Hi Jeff: My name is Jerry Berger. I am interested in the ATR headers. Would it be possible to get some pictures of the headers? If you can do that just e-mail them to me @ buickhotair@yahoo.com Thanks Jerry
intercooler
Hi Jeff: I am also interested in the intercooler. Please e-mail pics along with the header pics. Thanks Jerry
Interested in above.
PM sent
EDIT,
I made a folder in my Photbucket page, called PARTS FOR SALE, I am uploading pics to it now. All will be there eventually, but the ones asked for now I am doing right now.
I will wait for 100% positive sale before posting parts as sold.
dam those are some nice prices...
im intrested in this.. what are the fittings like going to the radiator and cooler??
punderwood@stx.rr.com
I WANT THE SPOILER AND THE RADIATOR......I have money NOW, let me know. thanks
