Alky System/Location Question
I'm in need of advice. Let me describe my set up and then I'll ask my questions...
Vehicle Description - 74 Vega, 4.3 turbo (with a/c & heat) P&P Vortec heads, 200-4R, 3.73 gear, TE-60, 72# injectors, F.A.S.T. system, FMIC, etc... Yes, it easily runs in the 9's!!!!!!!
I'm using the Edelbrock 2114 four barrel intake. I converted it to EFI and it has a 2" aluminum carb spacer welded on to ad more plenum space.
MY ALKY INJECTION IS IN THE PLANNING STAGE AT THIS TIME. IT WILL BE A 5 GALLON FUEL CELL, WITH A SENDING UNIT & FUEL LEVEL GAUGE INSTALLED, 80 PSI PUMP, FILTER, & 3/8 LINE.
Question 1 - Would a four barrel nitrous plate with the smallest nitrous jets on each end work for alcohol injection? I'll be using the 80 psi pump, 3/8 line, and a "Y" with two lines going to the nitrous plate. I'll be using either 90% isopropyl or methanol.
Question 2 - Will proper atomization be able to occur with the alky being injected so close to the runners?
Question 3 - Am I nuts for wanting to do it this way? I think (know) that this will be very visually impressive on the car. My car is pretty over the top so hiding the system is pointless anyway.
I know it's a Chevy, but I have owned two TR's in the past. I appreciate any help and/or advice anyone can give me.
