So ever since I bought my GN, it's always idled a little rough. Now, it sometimes backfires too on startup. Could this be a bad injector? Car has 93,000 miles and I bet the injectors are the original ones. Also, just recently installed a fuel pressure gauge and I've noticed a 20psi drop in fuel pressure within...oh, 10 minutes after shutting the car off. Should the pressure be bleeding down this quickly?
It runs fine at higher RPM, so I think that I may have one or more injectors with a bad spray pattern and/or a leak. Would explain the backfires and the quick loss of fuel pressure after shutting down. And probably the hard starting sometimes, too.
Can anybody tell me if I'm on the right track? I have some 009s waiting to go in, but I want the car to run perfectly before I put them in, unless I can say for sure that the injectors are the problem.
