black magic
Black Magic
- Jun 24, 2011
this car sat for 4 years its a 1987 ttype, i did a full tune up, plugs,flushed gass tank, fuel filter, coil pack, injectors, o2 sensor, 3inch lt1 maf, with translator. this car had a bent pushrod cylinder 3 intake pushrod, i put new lifters, and new pushrods, started car up drove it around a little and it bent the same pushrod, the lifters are good, and the rocker assembly is fine too, i think its caused by a backfire. the scanmaster shows a low o2 millivolt reading and it stays at 70. i tried 4 different oxygen sensors, im starting to think its a bad chip or bad ecu because it throws code 44 wich means o2 sensor lean, bad o2, bad 02 wires, vacuum or exhaust leak, wrong chip or fuel press too low. the fuel press is at 43 psi anyhelp would be greatly appreciated, also traced on wire in harnes no breaks????????????????????
