Yes the weatherstrip has to be removed. Be careful not to ripe the weatherstrip sometimes they are glued on. You will also have to remove the weatherstrip channel.It has sealant behind it to stop water from leaking in. Make sure you use a little butel tape when you're installing the channel.
