Twin Turbo T
- Jan 22, 2003
http://www.automachperf.com/v-6Savenger.htmlHas any one used a Automotive Machine & performane oiling system?
White Racing has one too that does not require notching the frame nor an extra line for the bypass. It does not have a counterbored gear pocket. If you want to run long pump gears, you use the hi volume cover or a spacer.
White Racing Marine - Your #1 Choice for Electronic Fuel Injection for Drag Racing. The finest aftermarket EFI Systems and Support money can buy. On Line assistance with you Programming Needs. File Downloads available including Software Upgrades
Dan at DLS has one now also.You do not have to notch the frame for it.
here is a link to some infor.http://www.turbobuick.com/forums/engine-tech/211759-external-oil-system.html
Dennis
Personally i prefer the Duttweiler or DLS with the external bypass.
I hook he bypass to the fuel pump plate and this way it always dumps oil on the timing set.Keeps the DIST gear intact.
I am on y second motor and with it setup properly by RPE machine i have had
no problem or wear in the pump at all
You use the DLS pump cover?
