V6 turbo Syclone, FAST classic B2B, air-air, IAT sensor in intake plenum (stock location)
It was really hot yesterday with my FAST for the first time. Ambient was almost 90. When i tuned my truck i left the ATS enrichment table zero across the board, i always let the engine cool down. Yesterday after a drive the truck sat, and the intake heat soaked. IATs stayed around 130-140. The truck idled completely lean, popping and sputtering, FAST WB read 15.9 (max) and my other WB was reading 18.4. I started turning up the ATS enrichment table above 100deg, but it just didnt help. Seemed like the more i turned it up the leaner it got, which doesnt make any sense.
Once the truck was moving fast enough to cool the IATs down, it ran fine again. Seemed like 100deg IAT was the magic number, once they dropped below that it was fine. But above 100deg it went dead lean.
The last i left the ATS enrichment table i was +20% above 140deg, and about +10% at 110deg.
I'll turn it up more if need-be. Is the ATS correction a function of closed loop? My idle/cruise rpms are in open loop, and i dont switch to CL until about 2000rpms.
Any ideas.
Any ideas.
