C chin_dude New Member Joined Mar 31, 2002 Apr 9, 2003 #1 Are other 200r4's similar except for the valve body (v6 rwd)? If so can you buy a separate valve body to replace and have a bfg 200r4? TIA
M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Apr 9, 2003 #2 The short answer is you'll need a valve body, governor, PR line-up and servo in the very least. This is a frequently discussed issue so if you do a search, you'll find an number of threads covering this.
C chris718 Active Member Joined Dec 10, 2002 Apr 11, 2003 #3 www.ckperformance.com has gn v body and we stock over 200 hp factory 2004r bodys and governors .
