I Intercooler New Member Joined May 24, 2001 Jun 6, 2002 #1 Just curious if they will hold up to our spring pressures or is you should stay clear of them. If you have or are currently using them, how long?
R REDS HOT AIR Buick Tweaker Joined May 24, 2001 Jun 7, 2002 #2 i have used them on sbc motor with stronger than z-28 springs and they worked out fine just make sure the top of the dampner in the spring has a flat surface so it dont cut into the alum.
