Anyone use a 7th injector?
LUZ_2_A6
Old School
I am building a car and it is going to have a 66-1 and 55s I have the 340 pump hotwired, do you think this is going to be enough, i will probably never go over 25-27 lbs of boost. Should i get a 7th and/or an external pump, or will i be fine? Thanks
NHH
you'll be fine....7th injectors are old tech.... before we had the selection of chips and injectors we have today...you will most likely run out of fuel pump before you run out of injector
