I already had a hotwire kit so I used what I had...Thanks for the info. Do you have the Raceronix hot wire kit.
Some have gotten away with not needing to go to a bigger return line and drilled out the saginaw fitting.....I went with a -6 braided return line so I wouldn't have to drop the tank again if pressure would not come down...Did you have to alter the return line to a bigger size due to the large pump having to much psi in the system?
Yes that's the exact pump
Bingo that's what I wished I would have done!!! There is an E-85 station that is not too far away and the 430 pump would have been enough to go E-85 and I would have just needed to update the feed line when I did the return...Still thinking about doing that!!Im on the fence whether to go ahead and upgrade the return line and go with a 430 LPH or something around there. Im not really wanting the wiring and switches associated with a DP setup.
yes that's the one im talking about,i was just referring to the whole assembly when I said "well put together piece"..
The Racetronix Pump that was originally questioned is an Aeromotive 340L.To further the 430 lph use....... if I ever did get in a situation where the 430 LPH wasn't enough then a boost a pump could extend the range if needed.
In the big picture...My tentative plan......cut the steel fuel line return line right where it comes off the front cover are/engine before the rubber flex hose, tie into the factory vent line since teh fuel vapor canister is not on the car anyways and use that as a return back to sender and then cut the necked down part of the original return line on the pump hanger/sender off and use the return, then just coil up some hose(like most fuel cell setups do) above in or around the tank and use that as new vent
