Marc87GN said:
What confuses me is why does the ARP catalog state that the 6 point and 12 point do not need to be retorqued, but yet people constantly state to retorque them? I would think they know there bolts design better than anyone else and they have been thoroughly tested. I retorqued mine dry while the engine was out after a week, but it would be a PITA to do it now with the engine installed.
http://www.arp-bolts.com/ARP_2005CatFinal(p)work.id2.pdf
Page 41 incase it doesn't go right to it.
I've read that page twice now and it doesn't say that. It says that the smaller bolt heads make it easier to retorque because you don't have to remove the valvetrain components.
Here's the text from page 41 (bolding mine):
CYLINDER
HEAD BOLTS
HIGH PERFORMANCE SERIES
High Performance head bolts are available with a reduced wrenching
hex or 12-point and wide area flanged head that
eliminates the
need for valve train removal to facilitate cylinder head retorquing. All
High Performance Series bolts are 180,000 psi (which is 15% stronger than
Grade 8) and kits come complete with hardened parallel-ground washers.
PROFESSIONAL SERIES
All Pro Series bolts are cold-forged to ensure molecular integrity, heat-treated prior
to thread rolling and machining, and are rated nominally at 200,000 psi. ARP Pro
Series head bolt kits are application specific – designed for use with typically competition
only components. These fasteners deliver superior strength and meet the ARP
“ZERO defect – ZERO failure” quality standard. Hardened and parallel-ground
washers are included with each kit to ensure even load distribution and accurate
torque readings.
All Pro Series head bolts have a reduced wrenching 12-point head
and wide area flange to eliminate the need for valve train removal for cylinder head
retorquing and permits the use of larger diameter valve springs. Most applications
have undercut short bolts that can help eliminate head gasket failures through providing
more “stretch” to compensate for the additional compression of gaskets.
