Hey, can someone help me fix this problem with my alkycontrol set-up?
It just started pumping all the time when the car is "on". I checked out the wiring and found the shielding wire hanging loose under the dash, but I can't find a "big brown" wire coming from the PAC that it attaches to (according to the instructions). I've confirmed good grounds. The green MAP wire has 0.0v, the wire to it's left has 5.2v and grounding the black MAP wire makes no difference. I also noticed that my low-fuel bulb, which never worked in the past is now on! I'm guessing this is a wiring issue.
Any thoughts?
Thanks,
Tim
Any thoughts?
Thanks,
Tim
