1BAD_GN
1BAD_GN
- Nov 28, 2012
Alky doesn't come on with boost. If I turn key on and press the test button I can here pump engage, also if the car is running it will stumble when u press test. That leaves me to believe that pump is functional. The problem is while driving alky is not engaging when it reaches 12psi of boost. The indicator light doesn't come on while driving, but it comes on when test button is pressed.
I'm lost on this one
