Well.. see the Ford EFI pump was really designed to run with blends. That is alcohol mixed fuels. Not really straight alcohol. So if your using a lot of lube with the alcohol, that pump should work until run dry or???
The Shurflo issue I found a different twist on. See the materials used wont be compatible with oils and gasoline. Yet compatability with alcohol on the seals/materials is not a problem. Look at those who have used it for years now and no issues. The motor sticker issue from Shurflo is they're CYA wink wink deal.
If the concern is safety, then mix the alcohol down with water, and run lower boost. But dont run water/mix on an EFI type pump. That will kill it in short order.
I personally have been running 100% methanol alcohol through my pump for over a year now, and no issue. In other words, my pump has had long term contact with methanol, and not had any problems.
If you want, there are companies that sell sell alcohol pumps for use with EFI systems, but expect to pay a huge premium. And I have no data from weldon, aeromotive, BG, etc that sell the pumps for use with race cars and alcohol.
The Flojet has the same issue as the Shurflo. As long as there is electrical connected to any pump, there will always be a possibility of a spark issue. There is no 100% anything.
