If I go from a stock MAF to a LS1/translator MAF (with no other changes) will that normally require or not require retuning the alky settings (turn-on, initial or pump speed). I have the Razr single nozzle Alky system.
Once you make any changes you need to sneak up on your tune again. But you shouldn't need to change your alky settings. Unless you have really been jacking around with Julio's basic settings.
