adjusting the wastegate
GW2
Which way is up in psi and which way is down, and its 1 full turn per pound of boost correct?
Shorten it to raise boost About 1 turn is 1 lb.
Have you read here at all? www.vortexbuick-etc.com
It should be mandatory reading.
Also being in Ontario go to the other site with an "S" on the end & check Toronto serction. 100 guys from all over hang there.
ya i know about the other site. not as active as this one though. and i have read that in the past but havent for probably a year. need a re-read. Thanks for the help!
Oh and you missed the s on the end of buicks in your link. just letting you know.
