Look at voltage coming from your 3 bar MAP. It (green wire) should be approx 1.6 "Key ON".. and when you start putting pressure on its nipple it will increase. At 2.2 volts the PAC activates.. There is a sheet included with the instructions that says "MAP Sensor wiring".
Perfect example is digital dash cars do not supply 5 volts to the sensor plug.. this is part fo the instructions.
Looking at wires is not the same as testing using a digital voltmeter. If you work on your car, invest in a meter.. they are cheap.. places like Harbor Freight sell them sometimes for a few dollars. Home Depot, Radio Shack, walmart, autoparts stores.. all carry them.
Your "Turnon" LED will illuminate once you cross 4-5 PSI boost. If it doesnt, you are either missing 5 volts DC to the MAP, or the airline to the map is cracked, broken, disconnected, etc. This 4-5 PSI is preset when the controller is built.. if you moved this setting(turnon).. then that could be the culprit.
12 hours a day.. Sat's I need off.. email(idoxlr8_70@yahoo.com) is best way to reach me after hours.
