My WB reads inconsistantly now after the turbo upgrade. Even before the turbo at WOT on stock turbo it would be 10.9 to 11.0. Now it's all over the place so I am thinking it's the fact the chip is set for the stock turbo and not the 4431 Precision. Even then though with a stock turbo it would pull good but just lacked the torque to break the wheels loose. I can not really believe a set of 275/60/r15's could hook up to the road that good. I am still convinced I should be able to smoke the rubber off those things.
What I am going to do is wait for the new chip from Eric at TT, install my new Pats 2800 lockup stall converter, the external fuel pressure gauge, the new O2 sensor and then retest the system so I can rule out those possibilities of tuning. I do know that my WB reads max on WOT 10.0+ but then drops to 12.8 or 13.9 after the turbo upgrade. I am not sure why but again it could be the fact I am running ALKY without an ALKY chip. It's still a TT chip but it's set up for everything execpt for the 4431 turbo and the ALKY. I am currently running 26psi boost w/0 knock according to the scanmaster. Car pulls good once the turbo spools but still lacks the torque and ability to spin the wheels. I'll keep you posted.
