Buick_noob
- Aug 24, 2006
Is this Sold yet??? Can I return the tranny under your name to get it fix?
Not sold yet. I looks as though only the original purchaser can use the warranty:
WARRANTY: All Performance Automotive and Transmission Center transmissions and converters are warranted for six (6) months from the date on the invoice. This is the date of purchase. During this period Performance Automotive and Transmission Center will repair at its option any transmission we determine to have failed due to defective materials or workmanship. The only exception to this is the MegaRaptor-1 and Bionic MegaRaptor torque converters have a two year defect warranty on materials and workmanship. All parts orders have a 30-day defect warranty. These limited warranties shall only cover the original purchaser. Any disassembly of the item without prior approval from Performance Automotive and Transmission Center will result in immediate termination of the warranty and will result in forfeiture of all rights of the customer under the warranty. We do our own warranty work. Taking the transmission apart or removing the pan will void your warranty. If you have a problem call 1-888-877-1008.
THIS WARRANTY DOES NOT COVER:
1. Transmission case breakage for any reason what so ever.
2. Planetary gear, shaft, drum or case breakage due to tire shake or misuse.
3. Pump and torque converter damage due to improper installation.
4. Transmission and converter failure due to improper installation or maintenance, failure to provide adequate cooling, not maintaining proper fluid level, misuse, abuse, wreck, unauthorized repairs, removal and replacement costs, shipping costs, transmission fluid, damage to related parts, costs incurred due to vehicle downtime, normal wear and tear or water damage.
5. Transmission failure due to breakage or misuse of other components such as but not limited to drive shaft, excessive use of nitrous or torque converters not supplied by us.
6. Transmissions that are used without a transmission cooler in the radiator.
7. Any and all incidental, consequential, property or personal damages what so ever.
8. Stuck valves caused by debris from a previous transmission failure.
You're selling your GN for a Porsche?!?!? Don't do it, those cars are for chicks.
