my 86 hardtop tipped the scales at just over 3210 (weighed weekly when at track and 1/2 tank) 3405 with driver laptop,safety jacket ,helmet
items that were in place or done to make it lighter
2004r 9" nl converter deep pts trans pan
hr rear swaybar (heavier than stock rear bar but lost the front bar)
glass bumper front and rear
alum bumper stands on rear
cf hood
ac box deleted with aluminum block off plate
champ ac delete bracket (still have ps)
fbody radiator (about 4lbs lighter than stock brass 3row)
stock boxed lower rr ctr arms, stock uppers,stock springs
fmic ( not a mammoth unit but a cas v2)
lt1 mini starter
took out the cruise control stuff , no spare tire or jack equipment
sound deadener removed from under carpet,and 1/4s
ive since done some things that added a few pounds .. some small some not so light but they add up
swapped the 200-4r for a th400 w/ larger vigilante converter ,
replaced the stock shifter with a b+M quicksilver
trans blanket , bhj sfi balancer,
razor dual alky kit , adds weight not just the system but also the gallon of meth, could remove it and run race gas (nah :biggrin
put back the power seat track on the driver seat
went to FAST B2b (its a little heavier than the stock setup)
replaced the missing hvac with a factory g-body heater only box and controls
electronic boost controller
hot wired the headlamps (hella h4)
hotwired the secondary dual intank pump
went to an aluminum maf pipe no cold air kit, also lost the maf with the fast
added solid rocker shafts
now she's at 3295 (3480 race weight)
there are areas that could be trimmed back to reduce it further --
it has vacuum brakes (manual brakes are considerably lighter and work just fine)
front suspension stock ( could go tubulars uppers loose 5lbs just on uppers)
has eibach front springs but going to coil overs withs 2" coils would loose weight
full interior all power options even a radio with concert sound speakers and power antenna
dont need a radio or speakers or power antenna
dont need lighted visors or any visors for that matter
has a console (none is lighter)
iron heads ( aluminums are lighter)
full 2 3/4 dual stainless exhaust w 3" magna flows (single shots are lighter)
was on 16x8 gtas245/50-16 fronts (welds and skinny's are definitely lighter)
dual fans hotwired (single is plenty for racing since it off at wot anyway)
stock 75 series battery (the oddysey looses 24lbs from stock)
still has the door impact bars and stock front bumper absorbers
4" steel mafless with cold air kit and 4" kn filter pipe (heavy could run nothing)
has razor alky kit that adds weight but could remove it and run race gas (nah :biggrin
still running stock tank which is heavier than a cell and add to that you need to carry more fuel with stock to run safely than you would with a cell
there is some equipment needed for the hp and safety items for the speeds but there is more room to trim in those areas if you arent concerned about running at the track and having to comply with nhra rules or overbuilding to avoid broken parts and a tow home
heavy duty 3" driveshaft 150 joints (stock was atleast 1/3 lighter )
33spline axles with a spool and clip elims (stock is about half the weight)
6 point mild roll bar (approx 85lbs) cm bars would loose about 30lbs
5point 3'' harness (7lbs) took out rears but still have stock front seatbelts for street
ds loop( 6lbs)
