mazdatech78
- Sep 30, 2004
I have an 84 040 14-bolt shortblock for sale. It is drilled and tapped w/ fitting for 86/87 turbo drain. I bought it off a board member and it turned out not to be what he said it was. The front cam bearing is shot and the crank snout is a little tore up from what looks like a balancer coming loose at one time in its life. It looks to have some aftermarket pistons in it but unsure of what they are. The motor comes with a newer balancer, front cover with NIB Melling oil pump booster plate kit. Also comes with an extra 14 bolt pan that I cleaned and painted. The bores have some surface rust from sitting. Pics available upon request. Thanks
James mazdatech78@yahoo.com
