Well I finally made it out to the track. Sadly I only got to make one pass before they kicked me out. :smile:
1.71 60 foot(Leaving at 0 boost/footbrake)
7.13 1/8 et
96.9 1/8 mph
11.20 1/4
118.8 1/4 mph
23 psi
25/21 timing
11.3-11.4 a/f thru out pass
0 knock
93 octane and alky
3850 lb w/ driver
I had the car tuned with the PL at 25 psi on the street last night and I turned it down to make a shakedown pass and get some A/F numbers. I didnt know it would be my only pass of the day. I also let out right before the traps because there was about a 4 foot snake(water moccasin) crossing the traps. I hit it and disentegrated it . (Got snake parts under my car ) There went my extra mph. We are in south Louisiana...I guess snakes like racing too.
I am showing about 17% slippage on this converter. I dropped a little over 600 rpms on each shift. I went thru the traps at 5710 rpms. I dont know what I lost with the snake crossing and me getting out of it. It might not have as much slippage with a few more mph in the formula.
As far as the turbo is concerned. I am very pleased with the power it is producing at these low boost levels. I wish I could have turned it up to the "sweet" spot.
My car usually does 1.58 sixty foots leaving at 5 psi. I thought I was going to get as many passes as needed to bring up my boost and my sixty foot as the day went on. I guess I have to take comfort that a good sxity foot and few more psi and it was going to run some good 10's.
All in all for a stock block and bolt ons I couldnt be happier running these time on street tires and pump gas.
7.13 1/8 et
96.9 1/8 mph
11.20 1/4
118.8 1/4 mph
23 psi
25/21 timing
0 knock
93 octane and alky
3850 lb w/ driver
