200-4R
Shaunz
2
0
1
49
I am new to your site and would like to put a 200-4R in my 63 nova and am looking for some advice on which casing would be the best choice. I will be putting it on a 383 stroker motor. So if there is any advice I would appreciate it .
mikestertwo
5,056
142
63
118
Warren, Oregon
Depends on the final gearing. Any of the performance transmissions from a SS Monte Carlo, Turbo Buick, Hurst Olds or 442 would be a good starting point. Codes CZ, OZ, BR, or KZ
TexasT
Texas, Where are you from
Sep 10, 2002
4,589
373
83
117
Texas
ihadav8.com
All about the same. The vb/gov set ups are what makes them different. The earlier units have a bushing in places that would get upgraded by a decent person doing the overhaul. The sun shell and stator support get replaced during an overhaul.
Really the most important stuff, at least to me, is getting the internal pressures up to the needed level, setting the clearances correctly, and getting the tv cable setup so the pressure jumps when the throttle is applied.
  • Like
Reactions: SS/GN
Top Bottom
