I think the main reason they are used is to add clearance for 4 inch inlets pipes, I have read conflicting opinions as to any performance gain and apparently they do not play well with power plates.
If you look at the tests that were performed at Richard Clark's facility you may be surprised. The spacer does add more volume but also allows the air more room to turn within the plenum.I will assume that they don't play well together because the PP was designed with the plenum volume only minus the spacer and maybe a little with how the flow changes due to volume differences with and without the spacer.
Might want to do some measuring first. If your motor mounts are in good shape, 1" spacer is probably going to put your vacuum block into the hood liner.
I have a 1/2" spacer and the liner has a witness mark and polished the top of my vac block.
That's the reason I always used a spacer on mine. Has there been any conclusive testing as to the proper location for the power plate, as it was designed to be placed at the mating surface of the intake and the dog house?If you look at the tests that were performed at Richard Clark's facility you may be surprised. The spacer does add more volume but also allows the air more room to turn within the plenum.
The spacer may help with my configuration (Hemco) since the hemco will tend to load up the middle (3 & 4) runners. What seems to be taken lightly in this air distribution stuff is that a ported lower intake with the egr chimney removed allows cylinders 1 & 2 to breathe better which tends to help lean back & middle cylinders. Also the lower plenum volume increases so the resonant rpm of the intake runners may change slightlyThat's the reason I always used a spacer on mine. Has there been any conclusive testing as to the proper location for the power plate, as it was designed to be placed at the mating surface of the intake and the dog house?
I run a champion spacer with a Hemco and of everything I have tried I believe that works the best. I blocked off the vacuum block with a plate and drilled / tapped the spacer for the vacuum lines. Much cleaner look IMO FYI we have spacers in the building ready to ship
Do you mind posting pics of this ? I was just talking to a guy and he mentioned the same thing I would love to see how this looks.
