Copy of invoice
What did they do to the car? Did you have them do the upgrades you talked about in your other thread?
I didn't do the other upgrades because I wanted to make sure my car ran good without those upgrades. I hit the gas one good time on my street and all of a sudden smoke starts spitting out. When I first got the car out the knock was reading red at about 40 mph so I wanted to take it back into the shop to have them check it out. They said it was reading wrong because of an aftermarket knock meter.
Tell me if I been had and overpaid for my work on my GN
White Racing & Marine Date: 14-Feb-08
Electronic and Fuel Injection Specialists Invoice #:
12820 E. Nine Mile Road, Warren Michigan 48089 Ship VIA:
(586) 756-3026 (586) 756-8350 Fax Labor Rate: $75.00
Resale: Fax: Same as Home VIN:
Quantity Part Number Code Labor Price Amount
1 Labor Check Out Car Completely 2.0
1 Labor Replace Lower Radiator Hose (Installed) 80.00
1 Misc Replace TCC Solenoid 0.5 88.75
1 Misc Transmission Filter, Gasket & Fluid 1.0 49.89
1 Misc Passenger Front Upper Control Arm Bushings 3.0 90.00
4 Misc Rear Upper Control Arm Bushings 2.0 78.20
8 Misc Rear Lower Control Arm Bushings 2.0 156.40
4 Misc Front and Rear Shocks 2.0 319.80
1 Misc Replace Rear Brake Shoes 1.0 64 64.98
1 Labor Replace Radiator and Flush 1.8 195.00
1 Labor Fix Oil Leak on Turbo (Gaskets, Materials) 0.4 10.00
1 Labor Fix Oil Leak on Front Cover 0.6 5.00
1 Labor Fix/Install Intercooler Bolts and Align 0.3 5.00
1 Labor Replace Misc Missing Bolts on Engine 0.3
1 Labor R&R Oil Pan and Replace Gasket 1.5 35.00
1 Labor R&R Valve Covers and Replace Gaskets 2.0 25.00
1 Labor Repair Broken Sway Bar Mounts 1.0
1 OLAB Front End Alignment 0.5 50.00
1 Labor R93 Chip, Setup ECM, MAF, TPS, Ect 1.2 75.00
1 Misc 160 Thermostat 1.0 15.00
1 Misc Cold Air Kit 1.0 175.00
1 Misc Hemco Plenum and Block Heater Hoses to Throttle Body 1.0 275.00
1 Diag Repair Dash 4.0
2 Misc Antifreeze 31.98
6 Misc Motor Oil 33.54
15 Waste Waste Disposal 0.36 5.40
1 Misc Oil Filter, GN 8.99
1 Deposit CC Deposit 1-25-2008 D 1,500.00
1 Misc Front Coil Springs (New) 155.00
1 Misc OEM Driver Lower Control Arm (Used) 65.00
1 Labor Labor to Install Lower Control Arm and Both Front Springs 3.0
1 Misc Install Polished S.S. 3" Downpipe 1.0 450.00
1 Ship Shipping on Down Pipe S 22.00
1 Misc Repair Drivers Side Exhaust Manifold (Sheared Bolt) 0.5
1 Misc Exhaust System - Used OL 300.00
1 Misc Waste Gate Actuator, HP 0.5 125.00
1 Misc Chassis Dyno and Road Test 0.00
1 Misc Fuel, 93 33.00 33.00
Description
6 24 Autolite Spark Plug 0.5 17.82
1 Misc Heater Core 2.2 65.00
CODES: # = Labor Hours B = Balance (Previous) C = Credit D = Deposit DY = Dyno Usage L = Labor M = Machining OL = Outside Labor S = Shipping Parts Total $2,578.75
Thank You for your Business… Michigan Repair Facility Number F152792 Tax $154.73
Labor Total $2,915.00
Outside Labor $0.00
Dyno Rental $0.00
Machining $0.00
Shipping $22.00
Total $5,670.48
Previous Balance $0.00
Credits/Deposits $3,000.00
I have read the above disclaimer... Customer Signature: ____________________________________________________ Balance
