MassiminoB
- Feb 14, 2012
Hi all:
I'm new to this forum, but figured this would be the best place to get reasonable responses to a wanted ad. I've been mostly on V8buick (for my '65 GS) and opelGT (for the opel GT) forums. My opel is slowly coming along (the 12-pt cage is nearing completion), and it's time to start looking about drivetrains.
I'm looking for a complete motor + trans from a GN or T-Type. I'll take a built motor, to an extent. I don't need anything too crazy, as this will be going in a ~1900lb Opel GT. Below is my wish list; I'm willing to compromise on things, since I know it might be tough to get exactly what I'm looking for. I'll also consider a non-Turbo variety, but would require the non-turbo to be built to ~300+ hp - likely requiring performance heads, cam, injectors, etc.
Motor:
- As complete as possible, including: exhaust, turbo plumbing, turbo, intake, throttle body, injectors, oil pan, oil pump, water pump, etc, etc.
- ECU harness and computer
- About 400whp is the max I think the car will be able to handle. But, let me know what you've got.
- Motor must be in usable condition - that means no knocks, bent rods, low-compression cylinders, major leaks (I'm willing to change gaskets & main seals while the engine is out, but don't want to do an entire rebuild), or otherwise major work to get it operable & reliable
Trans:
- Again, complete is key;would like everything from tailshaft to torque converter to be there, and in usable condition
- Trans should be matched to the motor. That is, if the motor is 400hp, the trans should be built to handle it.
Rear:
- This might be a stretch here, but if anyone has a narrowed 9", 8.8", or 12-bolt to fit an Opel GT, let me know. If you need measurements from my stock rear to gauge if yours is in the ballpark, let me know.
I'd prefer something "local" to Columbus, OH - within 4 hours driving time - to save on freight. But, I won't rule out shipping if the price is right.
You can contact me through PM, or directly through e-mail: brett.mass at gmail (!dot!) com
Thanks in advance,
Brett
Motor:
Trans:
Rear:
Thanks in advance,
Brett
