Wrong Converter
slo-joe55
How do you know if the stall in your converter is to big or to small, for your set-up. Hope i stated that clear enough.
I would think if too high of a stall speed you'd have nuisance wheel spin leaving stop lights with lousy top end power & too low of stall speed would feel like you were towing an anchor on the bottom end.
deezdad,
Thanks for the reply.
if u cant do a burn out way to low ... if it blows the tires off its too high ... pretty simple
put car in nutral rev rpms pressbrakes... hold them.. see when car spins or wants to move
Take the car to the track and make a balls out run. Post the PL file and let Dusty and Bison go over it. They'll be able to tell you what your convertor is/isn't doing...and what improvement(s) can be made.
