I changed the plugs and wires the other day, and after I did the job the car wouldn't turn over. I charged the battery over night, and still nothing. The starter engages but it won't spin the motor. Tonight I tried a new starter and it did the same thing. I hooked jumper cables to my powerstroke, which has dual batteries and dual alternators and still nothing. It would even dim the headlights on my truck a little when the starter engaged, but it wouldn't spin. I bench tested both new and old starters and they seem to be fine. The cables are nice and tight at the battery, the only cable I didn't check was the ground to chasis connection. I tried turning the motor over by hand with a breaker bar and socket on the crank pulley nut, it wouldn't budge. Can the motor be turned over manual like this with the spark plugs still in or is the compression to strong. Sorry if I'm rambling, but I'm worried this could be something big. Also I should mention that I drove it last week and it was fine, no bottom end noises or anything. Where do I go from here?
