Won't engage reverse when warm
89mulletbird
I have a built 200R4 and it recently does not like to engage reverse when it's warmed up. Fluid level is fine, TV cable is adjusted. I was thinking of installing a 300PSI sensor and wiring it to powerlogger, would this be useful to diagnose the problem? I'm guessing it might be the pump? All forward gears work great, shifts are crisp.
Could be a cross leak in the valvebody gaskets, could be bad low/rev seals, could be bad direct drum seals/rings on center support. Pump does not know forward and reverse. It always turns the same direction making pressure. I would guess the pump is the least likely of the issues.
Pressure test first
Left side above shift linkage slightly forward.
Line pressures COLD
Park 100psi
Drive 150psi
Reverse 220psi (engages well)
Line pressures WARM (190 deg)
Park 50psi
Drive 100psi (seems to shift OK)
Reverse 80psi (won't engage)
