S sawmillman Make logs into lumber Joined Feb 26, 2007 Feb 10, 2010 #1 I'm working on a 86 in the fuel wiring.The green wire goning to the relay is it a positive or a negative wire.It is a trigger wire I know just want to know if it is + or -.Thanks
salvageV6 Daily Driver Joined May 25, 2001 Feb 10, 2010 #2 Dark green with white stripe is a +12 relay trigger wire from the ECM to the coil of the relay. 1987 book though.
S sawmillman Make logs into lumber Joined Feb 26, 2007 Feb 10, 2010 #3 Thanks that what I needed to know.I think that 86 87 should be the same.:biggrin:
