Wilson TB Clearance
If that elbow is the same height as the PTE , yes it will with no issues. I run a victor E with 1in space and have plenty of clearance.
Louie not sure if it's the same height as a PTE elbow . from what Ive been able to gather it is 6" high . Thanks .
maybe it's the pic . But the Wilson looks higher IMO . The base on the Wilson looks thicker .
My PTE has the thick base also, not that thin one. Im confident that you will have clearance.
wow..I'm actually amazed one of those elbows with a 1" spacer would fit under the hood . :) Thanks for the info Louie . :)
I have the thick based PTE with a 1/2 spacer on a victor jr with plenty of room. I'm using a front mount I/C so the pipe going into the intake is close to the hood with about 1/4'' space.
I see that the Precision Intake Elbow comes in a 90 degree and 100 degree . what is the advantage between the two ?
PEP023-1006 - 90 degree (Forward)
PEP023-1005 - 100 degree (Forward)
The 100 degree angles the t-body down another 10 degress from the 90 degree one. I run the 100 degree one, for hood clearance reasons. I believe most people use that one
Mine is a 100 deg also. But that doesnt change the overall height of either elbow.
Something I should mention, mine is a side facing unit. I have to use the one inch spacer, otherwise the IAC adapter with not clear the fuel rail.
