Will these frame mounts work
mcolor
I'm removing my 3.8 carb out my 86 regal and going with a 350 will the frame mounts work are do I need a different set.
The problem is your going to need the mounts for the engine side. the rubber mounts on the chevy engine are on the frame and the steel mounting is on the engine. The frame mounts are available at napa 6021179 is the part number for those. Might be better off getting solid mount kit from Jegs or Summit. Good Luck
Use the mounts if you have a donor car. If not they have a bunch you can buy from Jegs or Summit that will work. Also the pads have to be moved up toward the front of the car. GM pad only use three of the holes on the g body frame.
