It's caused by voltage drop in the wiring. That voltage you are reading is ignition voltage not battery voltage. As your rpms go up the current draw from the ignition system is higher causing a higher voltage drop in the wiring. If you read battery voltage you will find it does not drop.Installed the 140 amp alternator. At idle voltage on scanmaster is 13.5-14.2. At wot it still drops to 12.4-13. Why??
Is your fuel pump hot wired? As with the ignition system as when rpm and boost increase the current draw by the pump increases do to the increase in pressure which gives more of a voltage drop in the wiring.I thought maybe it was my problem, not enough voltage to fuel pump.
I noticed today if I eased into the throttle and kept it around 3/4 of the way, around 14-15 lbs of boost,that fp stayed around 60 lbs.
As soon as I push pedal to floor the fp drops to 50-52 lbs. Boost around 18 psi, didn't matter if idle fp was set @ 42 or 46.
Only thing I can think of is that fuel pump is weak.
Good question, I'm looking at a data log voltage was at 15 wot 12.5, once off the throttle back to 15.
Hook up a 3 wire volt meter and read voltage direct from battery http://www.amazon.com/gp/aw/d/B00Q7...er+3+wire&dpPl=1&dpID=5105SRg81AL&ref=plSrch#It's caused by voltage drop in the wiring. That voltage you are reading is ignition voltage not battery voltage. As your rpms go up the current draw from the ignition system is higher causing a higher voltage drop in the wiring. If you read battery voltage you will find it does not drop.
Haven't seen a schematic for this mod.. Might you have such?I had this same issue until I wired in the sense line.
Here is a picture of the connector I took off of a front wheel drive car. The brown wire is the normal lead that goes to the idiot light in the dash. The red lead I ran down to the starter terminal where the fusible links are.Haven't seen a schematic for this mod.. Might you have such?
Tia,
The problem I see with this , is the alternator is regulating its voltage output based on what it's "seeing" somewhere down stream in the harness after many questionable 30yr old connections . The voltage you need to "see" is at the output of the hot wire relay to the pumps & or injector harness . Those are the places where low voltage under load will be a problem , 12.5 v at the powerlogger and ecm is enough for it to function properly . If the alternator is putting out 15v but it "sees" only 12.5v due to a remote sense lead , it will try to raise the voltage even higher ( more than 15v ) to a point where it can damage other components . If the overvoltage is prolonged it also can overcharge the battery . I believe sensing the voltage at the back of the alternator is best and if there is big voltage drops down stream you have wiring issues . SamI had this same issue until I wired in the sense line. My voltage never goes below 13.2 volts showing on Powerlogger.
I guess GM doesn't know what they are doing again Just about every GM vehicle is wired this way. It's common practice in power supply wiring in electronic equipment. If you have a wiring problem...fix it! The sense line is tied to the positive battery cable down at the starter solenoid where the fusible links are that power the electrical system. Sensing the voltage at the back of the alternator is actually the worse place to sense the voltage since it can't sense the true demand on the electrical system because of line drop in the feed line to the battery. It won't "over charge" the battery since the sense line is tied in just after the battery on a very heavy cable which has very little line drop.The problem I see with this , is the alternator is regulating its voltage output based on what it's "seeing" somewhere down stream in the harness after many questionable 30yr old connections . The voltage you need to "see" is at the output of the hot wire relay to the pumps & or injector harness . Those are the places where low voltage under load will be a problem , 12.5 v at the powerlogger and ecm is enough for it to function properly . If the alternator is putting out 15v but it "sees" only 12.5v due to a remote sense lead , it will try to raise the voltage even higher ( more than 15v ) to a point where it can damage other components . If the overvoltage is prolonged it also can overcharge the battery . I believe sensing the voltage at the back of the alternator is best and if there is big voltage drops down stream you have wiring issues . Sam
