Instead of injecting more and more alky and less and less gasoline like a lot of people are doing, why couldnt I just build a separate fuel system for alky that was activated under WOT? To completely shut off the gasoline to the injectors and supply them with 100% alcohol?
You would need a sepatate fuel cell, pump and lines for the aky and place a solenoid in the main fuel line just before the injectors to close the main gas line and open the alky lines, and have a TPS controlled switch turn on the alky pump and open the fuel line.
I know it would need a lot of refineing but wouldnt this be a more effective and easier to tune system then just injection?
