If there was no issue with what was on the motor before the freshening.. i'd leave the old sensors alone. At least they worked before the motor was pulled. Why risk installing a bad new sensor and making a mess when you restart the motor.
If the engine had a lot of miles, I would use a brand new cam sensor..since this is a wear item. Bushing,bearings, etc get play. teeth get scored, etc..
See i'd leave the old sensors on the intake and such, use a new cam sensor and new O2 sensor AC Delco AFS20. The knock sensor... if you want to change it.. get a new AC Delco one. Notice I use the AC Delco designation.. not wells/standard/GP sorenson/etc
HTH
