I was a little off. I actually used the braces that cross in front of the radiator.
Here are some pics I shot last night:
This is from the pass. side. You can just see the hard lines comming from above. You can see that I placed split tubing over any contact points.
Drivers side Pic.
The hard lines from the top. Trans fluid goes into the stock cooler at the bottom and exits at the top. From the top rad. fitting I go down to the second cooler, then back up to rejoin the factory line. I used short pieces of tube between the hard lines as spacers and for support. Once screwed together there is no flopping around. The long piece of tube on the upper line is not a joint, it is there to keep the hard line off the radiator.
Here is the deal. Making the bends is kind of difficult. A decent brake line bender will do it, just practice a few times and expect to waste some line. Untill I got the hang of it I help getting bad flat spots on the peek of the turns. The hardest one was the one on the top line where it goes into the rad. fitting. A tip would be to leave the rad. fiting side long, make the bend, then cut off the excell length. Otherwise the line tends to pull through the bender and fold/flatten at the curve's peek.
Also, very important, get a double flaring kit!!!! They are not that expensive for a non-pro type kit, home mechanic type of kit like mine. If you already have a tube flare you can pick up the fold over dies (sp??) for cheep. Like I said, double flare!! This line is under pressure, given not as much as a brake line, so without a double flare you always run the risk of the hard line splitting at the seem in the flare. If you have any questions just drop me a line at
brent@brentg.net.
Brent
