FWIW, I take a piece of masking tape..... lay it flat on the table...... make a mark.... then take my calipers..... and measure off 1.45" and make the other mark........ then stick this on the balancer.
ok and 1 more little thingy i just changed my car over to an intercooled setup engine harness and all and im still using the 85 computer that came with my car whats the differenve between 84-85 computers and 86-87 computer?s
ok i got ya on the computer . stock maf also.93 fuel.you need to change to an intercooled computer and a updated chip what maf are you running? it could ping for many reason what fuel are you running? have you verified the timing on chip?
Also try and take the rod on the actuator off the turbo, no boost and take it for a spin see if its pinging or if you have any knock while n/a. Stop driving the car till you figure out the pinging you will blow a HG or worse throw a rod etc...
what year stock maf? 86/87 maf ? or the hot air maf?ok i got ya on the computer . stock maf also.93 fuel.
