If we are talking about the resistor that mounts down in the top of the blower motor housing on the passengers side cowl - then my suggestion - is to do like I always do and take all of them while visiting the boneyard and spotting anything 78 - thru Years 1988...G body or even Chevy Caprice or Pontiac Parisienne.
While the G bodies - or more specifically - Regals, may be a tougher find, there are always lots of suitable era cars to pick apart.
I not only grab the motor blower, clip the wiring harness portion (you can use it to test the blower motor), the A/C relay since they always need to be painted silver anyway, and the fan resistor.
Most time the pull-a-parts yard hardly will charge you for that resistor if you are buying anything of consequence.
I chrome or powdercoat the blower motors all time
So, for me - it usually also includes the wiper motor and wiper arms (hard to find new - and again - even if bright color - they paint black just fine), the wiper arm connecting bar - (it's usually nasty and can use a nice powdercoat), the lower windshield reveal molding (even if stainless as they paint up to black nicely , the squirters, the squirter hose clips on the cowl, the wiper arm rests and etc. Window surround reveal molding - but oft times the rubber seal is wasted. Cowl to hood rubber seal if it's decent as well gets pulled off.
While I'm in that area, I also grab a lot of the frame / hard line clamps and screws since they are kind of a special type screw (large), and those clamps can always use a re-freshening on my cars.
Fuel vapor cannisters also if you get lucky.
I always grab 15" - 4-3/4" lug pattern steel rims w/ tires for car purchases (oh it doesn't go with those wheels) , my roller or paint projects.
Keep your eye open for the correct sized space saver spares - those aren't the easiest to find either since so many late models have different lug patterns, use a large front wheel drive type offset, or use a much smaller spare.
It's just nice to have a lot of these pieces available for refinishing and re-installation when the mood strikes.
Hit that local boneyard regularly to keep your misc parts bins stocked!
Those G bodies and such tend to get picked apart quickly - then squished to make Korean rebar.
