T that national Member Joined Mar 3, 2006 Mar 12, 2011 #1 since i suck at math and cant figure this out, what would the total valve lift be on this cam 215/220 .516/.529 with 1.65 ratio rockers?
C charlief1 RIP Charlie! Joined Sep 20, 2007 Mar 12, 2011 #2 First, what rocker ratio is the cam calculated for?
T that national Member Joined Mar 3, 2006 Mar 12, 2011 #3 good question, its the revoultion x cam from full throttle. so im going to guess 1.55 maybe.
C charlief1 RIP Charlie! Joined Sep 20, 2007 Mar 12, 2011 #4 Ask them and make sure. Once you find out the rocker ratio used then devide the lift by that ration which will give you cam lift. Then mutiply cam lift by the ratio you want to use to get total lift.
9 9SECVSIX Member Joined May 25, 2001 Mar 12, 2011 #5 You will have .549" int and .563 ex with 1:65 rockers on that cam. 9sec.
