Hi,
Good call on your part,as a few of us neglect the covers,and then they leak. When I did my rebuild, I used the cork gaskets that came with the felpro kit. I am not familiar with the permadry model. What I did was to use permatex ultra as an adhesive and sealant,then put them on at 20 inchpounds,rotating the torque several times. It must have worked, because after 6000 miles, I have minimal leaks. I run this car hard every time I take it out, so if it was gonna leak,it would have started to do it by now! That permatex ultra is great stuff. If you want to trim your gasket, I assume it has tabs on it that are designed for the n/a stamped steel covers. I have a Craftsman Accucut, sort of like a pair of garden cutters with a razor in it that makes a perfect cut all the time. If you follow my instructions,you won't have leaks. Good luck with sealing issues!
