What pumps are you using to make big numbers on E85?
marleyskater420
still needs to learn
Just curious what the big players are running for pumps on E85. I'm looking into running a Fuel lab 41402 or a belt driven pump.
What's everyone here running?
I got a Fuelab As well, running 120's. I only live 15 miles from there shop. I've talked with Rick and hs partner directly. They are nice guy's very informative. I have the 41402 1300hp pump. They are coming out with a new regulator next year that is pressure sensitive. I regulates the speed of the pump, when at an idle the pump is at low speed, the more demand the higher thepump speed .
e85 pump
I'm running weldon 2015 with weldon regultor @ 45 psi with Moran 160# injectors. Have done 4 cars with same type of set up.
How fast are you wanting to go?
We just tested a stage 2 gn with an 88 last night. Weldon 2025 and 160's. Made some test hits but didn't make a full pass yet. Car is capable of 8.5's with the turbo it has. Hopefully next week we make a good pass in it and get some good info.
Buying an Aeromotive Pro Series off a guy next week. 1000+ lb/hr @ 80psi :)
I wanna go FAST!
Any news yet??? I am going the weldon route over the winter... also thinking 2025 with 160's on corn please let me know!!!!
-Dan
-Dan
I decided I'm gonna grab one of those little 2345a pumps.
I know, its tiny, and it'll flow "ok" amounts, but its all I can afford right now.
:p
We made a few test passes in the stage 2 e85 car last night. 24-25 psi, 6500 rpm, 9.6@146 1.65 60' traction issues.
Anyways, it has Weldon 2025 and 160# injectors. Duty cycle was 80% with e88 running 10.9 on the gas scale
LS2 88 turbo, Weldon 2035, 8-120 lb injectors 95% dc, .75 lambda, 750 rwhp mustang dyno, 18 boost... Time for some 160's
PM me for a place that has new 160s for 500$... i bought mine a few weeks ago from there for 90$ ea. sure enough a few weeks later they sell em for a few hundred cheaper...
