What is this off the front of the passenger side valve cover?
c0v3rr1d3
Noticed this piece has disintegrated and was wondering what it is and how to replace it.
Its coming off the front of the passenger side valve cover behind the turbo.
earlbrown
runs with scissors
It's a device designed to inject oil and crankcase gunk into the turbo inlet so as to sufficiently coat the entire intact track in oil, sludge and gunk to appease the environmental hippies yet make the car belch out more emissions.
Yanks it all off and get a filter kit from a vendor. It'll come with a small filter for the valve cover and a block off cap for the inlet bell.
C
coach
Guest
Earl...that was a fantastic answer. It read like it came outta my mouth.
Bravo!!!
TurboBuRick
Moderator
Staff member
LMAO! :D
Reggie West
TurboBuick.Com Supporter!
Don't throw it out. If you get your car smogged you will need it. Don't know which state you are in but check that first.
c0v3rr1d3
Thx, i'm in RI. While it still needs a safety and emissions test,the car will not be failed if it does not pass emissions standards. So i should be good to go.
GullsGN
OLD HIPPIE
You might also want to remove your intercooler and give it a flush. If it has never been cleaned you may find quite a bit of oil in there from that stock set up.
