A bleeder vs. a wastegate adjustment isnt really a comparison cause they work together. Ive tried a tight wastegate and a loose one with the pressure regulator and i prefer a loose wastegate because the bleeder is bleeding off so much air at low rpms that even though the wastegate tension is small, there isnt enough air in the system to really move it open until higher boost/airflow levels. Mine is only 3-4 turns past the closed puck position so there isnt alot of tension. Boost is easily controlled with the throttle but it is alot more sensitive than stock. i can get full boost with 2/3rds throttle but its still not like an on/off switch. It seems to slowly move the puck open below 1/2 throttle for quick spool, but then slams it open above 1/2 throttle, so I get no boost spiking or creep at all. If you want to hook the solenoid back up, do it, and turn the wastegate arm until you reach stock boost. From there on, write down how many turns of the arm it takes to get an extra 1psi. Garrett designed the turbos to get another 1 psi with each turn...or close to it. If it doesnt, there is another variable affecting it. But the factory solenoid boosts slow, and tuner style is even slower...alot slower on my car. The pressure regulator, set to bleed off alot of air at low rpms and less air at higher ones...not linear, (what mine does because its a very small regulator designed for controlling small amounts of airflow) with light wastegate arm tension gives really quick spooling for me, and I get about 2-3psi for every turn of the wastegate arm. I was messing with different setups for controlling boost, and Ive ended up really happy with what I have now.
