Not trying to highjack your thread, I cannot offer any information on "what causes a bearing to spin", I was compelled to say the following...
I am in a very similar boat as Clark6. I am able to work on everything from the short block up. Therefore, I had an engine built by a local guy who has very good reputation for building 25,000 dollar all aluminum big block chevs and mopar engines.
My 3.8L engine was the basic $4500 build with two steel center mains, forged TRWs, standard turbo crankshaft, hydraulic flat tappet, heads are Champion irons. I gathered all the information that I could and took to him, but it is a sticky situation when the amateur tries to the professional how to build the engine, bearing clearances and so such.
After I got the engine back 6 months later, I broke it in according to instruction. A short time after that..say a thousand miles, and a few track passes it incurred a subtle knock around 2000rpm, but would clear up after 3000rpm. I was told it sounded like a rod knocking by more than one observer.
After I finished crying in my beer, I took out the engine and took it back to the same shop. He claimed that he took the oil pan off and checked everything over and found nothing. After reading this thread I am not sure if he actually took off the center main caps to check the crank bearings. He did point out that the flexplate bolt holes were the converter bolts to were elongated and that the motor had visible signs of detonation, and this could be the source of the knocking. How does one dispute such a claim. Detonation is a gray area, it lies in between a good tune and a bad one, or between a good engine and a spun bearing, or between a busted engine being the customers fault vs the ability and knowhow of the engine builder. I am not a tunning master, but I can read a scanmaster and an EGT probe. I chase fuel with boost, not the other way around.
Let me get to the point... THANKS to all the professional and semiprofessionals that respond to these threads. You are our sometimes our only source of information that levels the playing field about these engines. You shed light into the dark abyss of the short block. I would love to have a great Buick shop near me, and you guys that do consider yourself lucky. If I want a Buick guru to work on an engine, it means shipping cost out the wazoo. I think in an idea world we would all have the knowledge and the tools to work on our on stuff, and share opinions. But the reality is that there are to many who know too little, and like a moth to a flame we are drawn to the turbobuicks, only to find out that the flame is a spun bearing.
I love these cars...
